Suggestions
DennoN
AIMP for Windows: "Preferences" window as a popup/different window
Topic: AIMP for Windows: "Preferences" window as a popup/different window (Read 6671 times)
January 06, 2020, 15:34:08 »
𝗞𝗡𝗧𝗥𝗢
Карма: +76/-1
Hi! You can email me or contact me via Telegram.
Hello all,
First and main,
happy new year 2020 and decade to all the AIMP users
I was thinking of a new feature to AIMP for Windows, which I needed some time to be honest. Would it be possible to make the
Preferences
window to be shown as a separate window? So, you can have 2 AIMP windows at the same time: the main AIMP window and the Preferences window.
This would be an optional feature (enabled or disabled). If someone does not want to use 2 AIMP windows, he/she could use as it is now.
I think of this because sometime I needed to test some settings while playing some tracks and had to switch between the AIMP main window and the Preferences window, very, very often. So I think that with 2 simultaneous AIMP windows it will be easier to test some AIMP features by using the AIMP main window and the Preferences window at the same time.
Thanks for reading!
Re: AIMP for Windows: "Preferences" window as a popup/different window
January 06, 2020, 18:56:19 »
Карма: +3239/-85
But Preferences window is already displays as non-modal window.
January 06, 2020, 20:37:46 »
𝗞𝗡𝗧𝗥𝗢
Карма: +76/-1
Yes, that is right. However, AIMP still appears as one window in the Windows taskbar. And the
Preferences
window is always on top.
Suggestions
DennoN
