Suggestions
DennoN
Things i would like to see changed or added in the app
Topic: Things i would like to see changed or added in the app (Read 3947 times)
January 02, 2020, 10:05:58 »
shaddyville
Карма: +3/-0
Hello Artem, I would like to ask if you will make a few changes for the app.
These include..
Function to exclude a sub of a parent folder in the file database monitoring system
(So like instead of it having a tick it will have a X on the checkbox)
Eample:
somestuff/firstpage (tick)
somestuff/firstpage/differentfolder (x)
So somestuff/firstpage/differentfolder will be excluded while everything else in somestuff/firstpage including other sub folders will be included in the library monitoring system.
Whenever I hover the mouse to the app's tab on the taskbar and the preview window comes up, sometimes I don't see the right image being displayed, all i see sometime is just a blue screen in the preview window..
..To get around this I use Regedit to modify the ExtendedUIHoverTime
That way I won't see the preview window at all (which would also take effect for other apps) since I do not like seeing that blue screen.. This is the only app I see that does this and so I'm assuming it's because of some modification the app does in terms of what it does with the preview window
I would like if there was an option to remove buttons and all other modifications done in the window preview on the taskbar by the app (Currently whenever i choose to not show buttons it does not seem to work but that a load screen is usually shown in the small preview window instead but the buttons are still shown, even after exit and restarting the app for the settings to take effect.
The main thing I do not like about the app is If the app is maximized and I pull/drag the grey area of the player, it will be detached from the edge of the screen and change to restore mode (Undocked)
Can you add function or just make it so that nothing happens when this action is done? ..That way it can stay maximized.
It is really annoying when that happens.
These are some of the changes that I would like to see and I feel would make the app even more pleasurable to use..
But as usual, thanks for everything else thus far. I just would like if some of these things will be changed for the better soon. Okay
Suggestions
DennoN
