Suggestions
DennoN
Change file path music library
Poll
Change file path music library?
Compress music library?
0 (0%)
Ram Disk for music library?
0 (0%)
Total Members Voted:
0
Topic: Change file path music library (Read 6640 times)
January 01, 2020, 00:49:53 »
Salpeter
Hello
by the time I have 120,000 songs on my SSD. My Windows system is fast, has enough RAM but the music library has become slower and slower, in fact the images are crawling. Now I have the idea to put it all on a ramdisk. I'm afraid the problem is internal to the Aimp but to continue, please can you help, how can I set up Aimp? I want to change the folder path instead of "C:"\Users\PC\AppData\Roaming\AIMP >>> "R:"\Users\PC\AppData\Roaming\AIMP...
Thank you all and Happy New Year!
Re: Change file path music library
January 02, 2020, 23:16:39 »
JD
Карма: +109/-3
AIMP has portable mode.
January 04, 2020, 18:15:50 »
Salpeter
Hello JD and thank you, but the protable mode is not an approach to the solution. Once again, I have two things to do, first I change the aimp profile path to another drive, this is easy and no problem. In the second step and here is the problem, I cannot change the settings inside aimp, the original profile path is fixed and not changeable to another path. Do you have another idea? Greetings from Hamburg.
January 04, 2020, 19:07:54 »
Zhenya
Тестер 3-го уровня
Карма: +328/-8
Perhaps a
symbolic link
will help you.
Suggestions
DennoN
