Active Waveform
Topic: Active Waveform (Read 4653 times)
Active Waveform
August 22, 2019, 07:21:15 »
Southernwave
Hello to all and apologies in advance if i have missed a answer to this question
Is it possible to control the player start point by clicking or wiping the cursor on the loaded waveform ? Sometimes I want to skip to a spot in the music without waiting to play until that point or go back over a section of the tune.
Thanks in advance
A
Re: Active Waveform
August 22, 2019, 09:08:56 »
JD
Карма: +109/-3
Maybe just try clicking?
Re: Active Waveform
August 22, 2019, 14:34:03 »
Southernwave
Does nothing
Re: Active Waveform
August 23, 2019, 12:06:23 »
JD
Карма: +109/-3
Works for me
Re: Active Waveform
August 24, 2019, 08:58:23 »
Southernwave
Apologies ... I went back several versions of my skin builds and yes clicking does work
Thanks
A
Active Waveform
