[x] [845] Playback stops if playback speed is changed
Topic: [x] [845] Playback stops if playback speed is changed (Read 5603 times)
June 12, 2019, 08:25:29 »
s/ash
Карма: +34/-1
Playback stops if playback speed is changed. To reproduce it, start AIMP with all DSP effects set to default, start playback then change change playback speed.
If you go back, press the play/pause button twice to pause then resume the playback, then playback speed can be changed normally for as long the current file is playing.
This problem exists from the public beta stages, but I didn't have time to report it.
I can reproduce this issue on both Android 8.1 and Android 9, stock.
Last Edit: June 12, 2019, 11:32:14 by Artem
Re: [x] [845] Playback stops if playback speed is changed
June 12, 2019, 11:32:21 »
Карма: +3219/-78
Fixed, thank you
