Suggestions
DennoN
Dark skin for complete AIMP, also Preferences (ctrl P), Tag Editor (F4)...
Topic: Dark skin for complete AIMP, also Preferences (ctrl P), Tag Editor (F4)... (Read 9746 times)
May 09, 2019, 01:11:49 »
froli
Карма: +6/-0
Even Windows himself created the first time since Win98 a dark skin for Explorer in W10 1809. I never had another Windows skin/theme since 98 thru various tricks, anyway, wouldn't it be time now to spend a dark skin (light letters on dark background) to complete AIMP? Thank you!
Just created my own AIMP skin (dark what else?) and every time i switch to ctrl P or F4 - booom!
Help! Where are the sun glasses?
Last Edit: May 09, 2019, 08:45:47 by froli
Re: Dark skin for complete AIMP, also Options (ctrl P), Tag Editor (F4)...
May 09, 2019, 08:34:03 »
beforetomorrow
My AIMP came with a dark skin already installed, just switch it by clicking the 4block button on the top right.
May 09, 2019, 08:44:46 »
froli
Карма: +6/-0
The 4block button switches only the player you can get 1001 dark skins for. But not the Preferences (ctrl P) or the Tag Editor (F4)...
Re: Dark skin for complete AIMP, also Preferences (ctrl P), Tag Editor (F4)...
October 31, 2019, 19:20:59 »
«G-Li†ch»
Карма: +17/-28
SO far:
1. Win 6.0~6.1: Dark scheme (classic/non-aero/non-
BRICKY
theme);
2. AIMP4 Preferences – Interface — General — Night Mode — Enabled
3. .ACS3 skin
Show AIMP4 Music Library.
64k-attachment removed (fixed in newer versions).
Last Edit: November 19, 2022, 14:50:23 by «G-Li†ch»
October 31, 2019, 19:27:51 »
Карма: +477/-74
https://www.aimp.ru/forum/index.php?topic=63700
October 31, 2019, 20:21:21 »
Карма: +3230/-79
Yep, this is known issue, it will be fixed in next update
Suggestions
DennoN
