Suggestions
DennoN
Do not delete tab/playlist if the last file is deleted
Topic: Do not delete tab/playlist if the last file is deleted (Read 4112 times)
April 20, 2019, 18:04:23 »
Dreamer
Завсегдатай
Карма: +12/-0
This is mainly for the Default playlist, when I move the files, Default playlist has one or more files which can't be played, so I delete them, but after the next AIMP start Default playlist is missing too, when I play another file, it's create, but the position is changed, so I have to manually fix it, this is quite annoying.
Could you add option to maintain the tabs even if it's empty, please? At least for Default playlist.
Thanks.
Re: Do not delete tab/playlist if the last file is deleted
April 20, 2019, 20:06:56 »
Карма: +3203/-77
ok
Suggestions
DennoN
