Suggestions
DennoN
Show VBR bitrate "changes" in realtime
Topic: Show VBR bitrate "changes" in realtime (Read 26030 times)
November 15, 2018, 12:39:27 »
untymage
I think it would be nice aimp shows the changing bitrates for VBR encodes in realtime (at the side of cover album maybe?) like this :
https://imgur.com/sVKhpSL
Re: Show VBR bitrate "changes" in realtime
November 15, 2018, 13:04:15 »
Карма: +1408/-191
what for?
April 01, 2019, 15:08:36 »
xeo
Карма: +20/-0
To know that it's VBR at least without going into tag editor. Skins can't show kind of bitrate, only its value.
But of course from what I know BASS library doesn't support showing dynamic bitrate values.
April 01, 2019, 15:22:56 »
𝗞𝗡𝗧𝗥𝗢
Карма: +76/-1
Hi! You can email me or contact me via Telegram.
xeo
Hello!
I support your idea. I suggested it in the past, but it was skipped. Anyway, I think the fixed value shown by AIMP is the average bit rate for each audio file.
March 16, 2023, 23:28:01 »
poisonborz
This should absolutely be implemented - if not live display, then at least in the form of "~Xkbps VBR".
There is no way to make a distinction if a file has eg. a fixed 140kbps encoding, or if that value is actually an average. Bitrate is rather important with formats like MP3, and the user should be able to see this info at glance.
December 02, 2023, 10:51:39 »
«G-Li†ch»
Карма: +17/-28
hm… display all used bitrates
on a timeline
would be even better.
Suggestions
DennoN
