Suggestions (archive)
Implemented in AIMP v4.60
[Реализовано] Add a Hide/Show Information Box hotkey
Topic: [Реализовано] Add a Hide/Show Information Box hotkey (Read 11149 times)
July 08, 2018, 20:33:13 »
sveakul
Карма: +81/-1
AIMP 4.51.2080. Would like to see the ability to add a hotkey setting for showing/hiding the Information Box window. Now that radio stream lyrics can be displayed there if found (thank you Artem!) by the WebLyrics plugin, a hotkey would make it simple to check on lyrics without needing to keep the Information Box open at all times.
Last Edit: July 20, 2019, 15:36:02 by Artem
Re: Add a Hide/Show Information Box hotkey
July 08, 2018, 20:35:49 »
Карма: +3227/-78
Its already implemented, refer to the Optiosn \ Player \ Hotkeys
July 08, 2018, 20:53:31 »
sveakul
Карма: +81/-1
Artem, I can only see hotkey for Information Bar (instead of Box), and for Current File Info (which does not display the lyrics, unlike Information Box).
July 08, 2018, 21:03:58 »
Карма: +3227/-78
Oh, my fault. You are right
July 08, 2018, 21:11:52 »
sveakul
Карма: +81/-1
Thanks for fast reply! Hope you'll consider adding that key for the next minor update
April 21, 2019, 04:06:52 »
sveakul
Карма: +81/-1
Artem, can this be added for the next 4.60 beta?
April 21, 2019, 13:12:30 »
Карма: +3227/-78
I hope so
July 18, 2019, 23:30:52 »
sveakul
Карма: +81/-1
THANKS for adding this in build 2137! Makes it fast & easy to toggle lyrics display on/off.
