Last.fm plugin - prevent from scrobbling particular directories
Topic: Last.fm plugin - prevent from scrobbling particular directories (Read 10185 times)
June 14, 2018, 08:39:48 »
MisterMike
Is there a way to prevent the Last.fm plugin from scrobbling some particular directories on my harddrives? Or the other way, tell it what certain directories to scrobble and hence avoid any others.
For instance, i might play some audio files that i use for my work and i don`t want them to be registered as 'music listened' since they have nothing to do with my actual musical favours. Or i could listen to some audio books, that i obviously don`t want to be scobbled either.
As far as i can see, i`m using the default plugin and these are the only settings i could find about it (the attached picture).
As i found out, the Last.fm original client has a feature of selecting particular directories for scrobbling them or not sacrobbling. But i don`t feel like using anything else besides my beloved AIMP you know
Any ideas / suggestions?
Re: Last.fm plugin - prevent from scrobbling particular directories
August 20, 2019, 20:22:10 »
wooshaq
Карма: +1/-0
Hello, you can use old Last.fm Client helper by Artem Izmaylov and Legacy Last.fm Desktop App from last.fm website.
Last Edit: August 20, 2019, 20:46:02 by wooshaq
