AimpWeb - Replacement UI for the control plugin
Topic: AimpWeb - Replacement UI for the control plugin (Read 12287 times)
May 30, 2018, 09:14:55 »
romlig
Introduction
AimpWeb is an alternative web interface for the AIMP control plugin. This is a project I did a while ago and only thought recently of publishing. Even if the code has not changed in three years, it still work with the newest AIMP version. It works well but sometimes lose the connection, especially on mobile devices. If that happens, just refresh the page.
To move items in the queue, either use the handles on the left to drag and drop or just click on them. The right-click can be used to reset controls or show track details. Press current track title to show it in the playlist.
Features
Color themes
A more “modern” interface inspired by the 2015's Music app of Windows 8
Sortable and filterable playlists
Web notification
Equalizer and support for some effects
Queue handling
A full-featured responsive mobile UI
Notifications on track change (disabled by default)
Automatic translations in about 50 languages, feel free to submit improvements
Installation
Install the AIMP control plugin:
https://aimp.ru/?do=catalog&rec_id=284
Open the Control Plugin Webscript folder (usually %AppData%\AIMP\Control Plugin\htdocs), replace everything in it by the content of the aimp-web-1.0 folder in the archive (if you want to restore the original interface later, backup the files first)
Restart AIMP
You can now access the web interface at
http://localhost:3333/
(this can be changed in the Control Plugin settings)
To access the application from another computer on the network, refer to the Control Plugin documentation.
Screenshots
The full source is included (no compiled files here except the language files, see README). See also
https://github.com/gilleswaeber/aimp-web
. I don't speak russian, so I expect the automatic translation to be a bit weird but basic stuff should be ok. Wherever possible, I imported translations from the AIMP lang files.
