Skin Editor, Skin Engine
Docked playlist on top
Topic: Docked playlist on top (Read 13454 times)
November 25, 2017, 19:00:04 »
firewolf
Карма: +1/-0
Hi, all.
I have spend a lot of time to figure it out how to make a docked playlist to the top side of the main player window.
However i cannot do it like i intend. When showing/hiding the docked playlist it moves the main player window up/down. I just want the player window on the bottom not to move.
Is this possible?
Thanks.
Re: Docked playlist on top
November 25, 2017, 23:52:46 »
Zhenya
Тестер 3-го уровня
Карма: +328/-8
So?:
November 26, 2017, 02:54:19 »
firewolf
Карма: +1/-0
Nope. This is the playlist window and it's fine. I am talking about playlist as a docked panel for All-in-One skin.
November 26, 2017, 03:18:06 »
gr-e
Карма: +174/-3
Try replacing the dock area with an empty container when playlist is hidden.
Not the prettiest solution but that's all I can think of.
November 26, 2017, 15:19:28 »
Zhenya
Тестер 3-го уровня
Карма: +328/-8
firewolf
, could you please describe in more detail what you need? Maybe with pictures. Which skin?
November 26, 2017, 22:39:56 »
firewolf
Карма: +1/-0
I have a solution. I just have pinned the playlist window to the main window with F11 in Skin Editor.
Now i need to know how to enable resizing of the pinned playlist.
November 26, 2017, 23:03:39 »
firewolf
Карма: +1/-0
You can check my work in progress here:
https://aimp.ru/forum/index.php?topic=58480
Last Edit: November 27, 2017, 01:06:48 by firewolf
