Imperator3
Kr1eger
Big Bento 1.4 colored version
Topic: Big Bento 1.4 colored version (Read 21692 times)
December 15, 2016, 12:00:00 »
rado84
Карма: +3/-4
Bulgarian
I took the original Big Bento 1.4 skin from this site (originally made by either Pro.Grammer or Svobodniy - not sure which one is the author) and modified it a little. Added some color to it in order to make it a little more "alive", so to speak (but some colors I couldn't change) and removed some buttons I never use.
Note that I made this modification mainly for myself
, so if you use any of the removed buttons, I don't recommend you to use my edition of the skin. I simply decided to stop being selfish and share it.
The text size of the playlist is changeable by the AIMP's function "scaling". On the screenshot below I've used 130% scaling.
Here's a link to download the skin. Soon I'll post a new screenshot since it seems the old one's gone.
http://www.mediafire.com/file/ycl7j4dcvla765d/AIMP4_Skin_-_Big_Bento_%2528edited_by_rado84%2529.7z
Last Edit: July 12, 2020, 06:23:01 by rado84
Re: Big Bento 1.4 colored version
July 11, 2020, 22:25:17 »
Yprom
Good day!Can I ask you to send me the project of your skin?Thank you in advance!
Imperator3
Kr1eger
