0 Members and 12 Guests are viewing this topic.
Small contribution from my side - German localization.I used last "Russian.lng" and "English.lng" files to be sure about context and place is right where the text is used.Not tested.I also have a small finding:214=text with information in the "modern" form will also be disabledHere in context, "form" is probably confusing because "layout" is meant and "form" has never been used in text before.
Can you re-make this "Radio capture [On]" button so:- it has accent color- it changes color on cursor hover (default darker)- cursor changes to hand cursor on hover
It is possible add 250% magnification to lyrics?200 is too small and 300 is too big.....
sorry but I dont see it
день добрый!A4 3.0.1 - окно обложки / спектрума / визуализации нельзя установить произвольного размера. сразу возвращается в исходный.A4 2.4.3 - нормwin11aimp 5.30.2563
заменяю на свой, менее срезающий частоту по спектру
моя dll уже не работает. альтернативу пока не нашел(((.
Why can't the A4 skin be the official default skin for AIMP6? At least it should be included in the AIMP installation package as one of the defaults.
This is localized file in Simplified Chinese
