иван_иванов and 5 Guests are viewing this topic.
1. I don't know why, but it is visible in default skin https://i.imgur.com/MCFEZBG.png5. Ok it's not a bug, my mistake, it just don't appear when the slider/wave is always visible.7. Yes in classic layout. You can put it in one of these places https://i.imgur.com/b4fybcG.png. I prefer near Playlist button.Thanks.
Can you make this line https://i.imgur.com/KW3c7hQ.png controling this line https://i.imgur.com/tftprIu.png ? In the miniplayer there is permanently %Artist. That one line in the settings (1st screenshot) is "free" (controling nothing) so maybe it could be used for this? The problem is when I set 1st line as %Artist (to have this https://i.imgur.com/U5xtWW6.png) in miniplayer Artist is doubled (2nd screenshot).
Maybe in the mini player make 3 lines. There will be 1, 2 and 5 lines. Or 2 lines and 1 and 2 will be edited.
The 4th line is used in Standard and Modern View
I'd also like to suggest an improvement.Could you please include the formatting options in the Comment-window like in the Lyrics-window?
Вы имеете в виду размер шрифта и выравнивание текста?
Вообще хотелось бы узнать мнение пользователей, нужна ли кнопка фонотеки или лучше сделать появление фонотеки при разворачивании плеера на весь экран?Варианты:1. Оба варианта2. Только кнопка фонотеки3. Только кнопка фонотеки и автоматического сбрасывания размера окна к "Классическому" виду, после скрытия окна фонотеки4. Только появление фонотеки, при разворачивании плеера на весь экран
In my humble opinion, the tabs of library should be highlighted just like the tabs of playlists.See the image: https://imgur.com/a/NXLBnYaI am using your version 2.7.2PS: As for your question, an on/off button is the best option.
