schalmock and 1 Guest are viewing this topic.
Great skin. Few suggestions:1a. Make these buttons a little darker (in dark theme) https://i.imgur.com/wULFaaS.png coz they are a little too bright on the dark background.1b. Make an option to disable it's background (like in M5 skin https://i.imgur.com/fKd8Tdd.png)2. Reverse the function of the album art buttons. I think the full cover preview is used more often than turning on the visualization, especially since the album cover is quite small. For example, I don't use visualizations at all, but I sometimes look at the cover https://i.imgur.com/fwedBgT.png3. I don't know what it depends on, but the font in the M5 skin is more clear and sharp. Is it a matter of the font type or contrast with the background? M5 https://i.imgur.com/89qqytA.pngA4 https://i.imgur.com/mX7vxJY.pngBold font option make them bigger, but even more blurred.4. Make an option to change tray icon to rectangular, to make the icon appear larger.https://i.imgur.com/siLT8aH.pnghttps://i.imgur.com/oYJhjLV.png5. Make the info panel font a little bigger https://i.imgur.com/iyFiksW.png6. I don't know if it's possible, but in all skins I always disliked the fact that the selected track in the playlist is more visible than the one currently playing (the background with the accent color is turned on). Is it possible, for example, to change it to dashed border or, add a background (accent color) to the currently played track and the selected/marked track will not have this background (only font color)?https://i.imgur.com/JXMGKvz.png7. The space for the track info in the miniplayer is too small https://i.imgur.com/NIuNYIt.pngYou can gain this space by reducing these spaces a bit https://i.imgur.com/jlQ1l2G.png
It would be good if the main menu did not have a hard-coded English translation of these lines. How can I change it to my language?
Такая возможность есть, но только при добавлении дополнительного пользовательского языка внутри обложки и дальнейшего его редактирования в skineditor. Могу выложить языковой файл, который вы можете отредактировать и я добавлю поддержку вашего языка в обложку.
Can it be done so that changed switches mode is remembered and changing to enable/disable mode don't reset it?
Yes, but when you disable some tracks and then you click this checkbox, all tracks are enabled again (you lose the setting of disabled tracks).
This is the standard behavior for a checkbox.
So this is a program feature and not a skin feature?
