Total Members Voted: 122
I tried your forked version. But now i can not play any type of video. (File: *** Code: -1 (FFFFFFFF) Message: File was not found.) Here is my plugin settings window:
Well... i was have the same problem. The Youtube-plugin from the AIMP-SITE plugins, IS not work...BUT! ...CUBIS123 users fork IS work fine! Download form here: https://github.com/jaryn-kubik/AIMPYouTube/releasesIf You have still problems (must be only codec...) then You must download and add the codecs from here:https://aimp.ru/forum/index.php?topic=34387.msg221403#msg221403...or if you need more codecs http://www.free-codecs.com/download/x265_hevc_encoder.htm-read the descriptions...Put the files (just .exe or ..plus the .dll files -nothing else files matter)here: C:\Program Files (x86)\AIMP\System\Encoders---------------------Now its should work fine!
if your having problems with this plugin then id suggest going tohttps://github.com/jaryn-kubik/AIMPYouTube/releasesand download aimp_youtube.zipafter you have it installed go to the plugin settingsand put this in:-f best[ext=mp4]/best30what it should look likehttps://i.imgur.com/DZBCfUX.pngafter that it "should" work
Tht installation did't work anymore. That's the problem : (https://imgur.com/a/bKWHP2yIt was very cool plugin
