Stereo Tool support
Topic: Stereo Tool support (Read 17365 times)
Stereo Tool support
April 14, 2014, 18:00:00 »
Vriess
Hi everyone
I just started using AIMP3 and I love it!
Just a small problem.
Before, I used the Stereo Tool DPS plugin in which was developed for Winamp but should support AIMP3 as well (according to the author of this plugin).
I understand that AIMP3 supports Winamp plugins as well but this one doesn't work.
When I install the latest Stereo Tool plugin it is visible in configuration menu under the Winamp DSP tab, but the main window of Stereo Tool does not open.
I posted this issue on the Stereo Tool forum and it was suggested there that AIMP3 is buggy and therefore an issue of the music player and not the plugin.
Can someone advice me on this?
http://www.stereotool.com/
Re: Stereo Tool support
April 14, 2014, 18:06:05 »
Карма: +1406/-190
https://aimp.ru/forum/index.php?topic=21694.0
April 14, 2014, 19:34:48 »
Vriess
Oh... I overlooked that...
Thank you!
Stereo Tool support
