0 Members and 113 Guests are viewing this topic.
У меня перестали вещать все потоки Радио RECORDТакого формата:http://air.radiorecord.ru:805/rr_aachttp://air.radiorecord.ru:805/chil_aac
E: http://air2.radiorecord.ru:805/rr_aac, HTTP server doesn't seem to support byte ranges. Cannot resume.GeneralCount : 326Count of stream of this kind : 1Kind of stream : GeneralKind of stream : GeneralStream identifier : 0Count of audio streams : 1Audio_Format_List : AACAudio_Format_WithHint_List : AACAudio codecs : AAC LC-SBR-PSComplete name : http://air2.radiorecord.ru:805/rr_aacFolder name : http://air2.radiorecord.ru:805File name : rr_aacFormat : ADTSFormat : ADTSFormat/Info : Audio Data Transport StreamFormat/Extensions usually used : aacCommercial name : ADTSCodec : ADTSCodec : ADTSCodec/Info : Audio Data Transport StreamCodec/Extensions usually used : aacOverall bit rate mode : VBROverall bit rate mode : VariableStream size : 0Stream size : 0.00 ByteStream size : Byte0Stream size : 0.0 ByteStream size : 0.00 ByteStream size : 0.000 ByteFileExtension_Invalid : aacAudioCount : 275Count of stream of this kind : 1Kind of stream : AudioKind of stream : AudioStream identifier : 0Format : AACFormat/Info : Advanced Audio CodecCommercial name : AACFormat version : Version 2Format profile : HE-AACv2 / HE-AAC / LCFormat settings : ImplicitFormat settings, SBR : Yes (Implicit)Format settings, SBR : Yes (Implicit)Format settings, PS : Yes (Implicit)Format settings, PS : Yes (Implicit)Codec : AAC LC-SBR-PSCodec : AAC LC-SBR-PSBit rate mode : VBRBit rate mode : VariableChannel(s) : 2 / 1 / 1Channel(s) : 2 channels / 1 channel / 1 channelChannel positions : Front: L R / Front: C / Front: CChannel positions : 1/0/0ChannelLayout : CSamples per frame : 1024Sampling rate : 44100 / 44100 / 22050Sampling rate : 44.1 kHz / 44.1 kHz / 22.05 kHzFrame rate : 21.533Frame rate : 21.533 FPS (1024 SPF)Compression mode : LossyCompression mode : LossyStream size : 18446744073709551615Stream size : 0.00 ByteStream size : Byte0Stream size : 0.0 ByteStream size : 0.00 ByteStream size : 0.000 ByteE: http://air.radiorecord.ru:805/chil_aac, HTTP server doesn't seem to support byte ranges. Cannot resume.GeneralCount : 326Count of stream of this kind : 1Kind of stream : GeneralKind of stream : GeneralStream identifier : 0Count of audio streams : 1Audio_Format_List : AACAudio_Format_WithHint_List : AACAudio codecs : AAC LC-SBR-PSComplete name : http://air.radiorecord.ru:805/chil_aacFolder name : http://air.radiorecord.ru:805File name : chil_aacFormat : ADTSFormat : ADTSFormat/Info : Audio Data Transport StreamFormat/Extensions usually used : aacCommercial name : ADTSCodec : ADTSCodec : ADTSCodec/Info : Audio Data Transport StreamCodec/Extensions usually used : aacOverall bit rate mode : VBROverall bit rate mode : VariableStream size : 0Stream size : 0.00 ByteStream size : Byte0Stream size : 0.0 ByteStream size : 0.00 ByteStream size : 0.000 ByteFileExtension_Invalid : aacAudioCount : 275Count of stream of this kind : 1Kind of stream : AudioKind of stream : AudioStream identifier : 0Format : AACFormat/Info : Advanced Audio CodecCommercial name : AACFormat version : Version 2Format profile : HE-AACv2 / HE-AAC / LCFormat settings : ImplicitFormat settings, SBR : Yes (Implicit)Format settings, SBR : Yes (Implicit)Format settings, PS : Yes (Implicit)Format settings, PS : Yes (Implicit)Codec : AAC LC-SBR-PSCodec : AAC LC-SBR-PSBit rate mode : VBRBit rate mode : VariableChannel(s) : 2 / 1 / 1Channel(s) : 2 channels / 1 channel / 1 channelChannel positions : Front: L R / Front: C / Front: CChannel positions : 1/0/0ChannelLayout : CSamples per frame : 1024Sampling rate : 44100 / 44100 / 22050Sampling rate : 44.1 kHz / 44.1 kHz / 22.05 kHzFrame rate : 21.533Frame rate : 21.533 FPS (1024 SPF)Compression mode : LossyCompression mode : LossyStream size : 18446744073709551615Stream size : 0.00 ByteStream size : Byte0Stream size : 0.0 ByteStream size : 0.00 ByteStream size : 0.000 Byte
Раньше можно было и LoveRadio, но они поменяли свою "защиту" и пока не поборол.
что-то совсем нет радиостанций в формате FLAC? кто может поделиться работающими ссылками?
У меня скрипт получает эти же потоки, для всех станций LoveRadio (11 штук), а сейчас "говорит", что вещание по данному адресу приостановлено. В общем как раньше было у 101. Видимо где-то еще токен добавляется.
Добрый вечер! Выложите кто нибудь пожалуйста Enigma в M3U Спасибо
Добрый День! Подскажите, Монте Карло Спб 105.9 я поиском так и не смог найти... его нельзя сделать, или я чего то не понял?)
