Having the same plugin "engine" does not guarantee that AIMP works the same as Winamp when regarding metadata extraction for currently played song. In your case, I am 99% sure that it only works when the song has no title, simply because AIMP doesn't use the same method of getting currently played info like Winamp does.I don't use AIMP, so the answer is no, there will be no separate version.
