Suggestions
Player
Internet Radio
Radio capture option in utility or main menu for skins without capture button
Topic: Radio capture option in utility or main menu for skins without capture button (Read 2487 times)
October 27, 2025, 07:21:32 »
Skyweaver
Завсегдатай
Карма: +2/-0
I've been on the hunt for AIMP skins and found that many of them lack an internet radio capture button, and I'd like to use the radio capture regardless of skin.
Perhaps someone could make a plugin?
Re: Radio capture option in utility or main menu for skins without capture button
October 27, 2025, 08:05:47 »
Карма: +3228/-78
What skins has no radio capture button?
October 27, 2025, 16:31:52 »
Skyweaver
Завсегдатай
Карма: +2/-0
Such as
https://www.aimp.ru/?do=catalog&rec_id=913
https://www.aimp.ru/?do=catalog&rec_id=233
https://www.aimp.ru/?do=catalog&rec_id=330
October 28, 2025, 09:02:40 »
Карма: +3228/-78
It seems that not only this button is missing in these skins, but also many others. It turns out that you need to duplicate ALL the functionality through additional menus. Or use keyboard shortcuts for these actions.
November 17, 2025, 00:28:16 »
Skyweaver
Завсегдатай
Карма: +2/-0
Perhaps it can be added in the Utility menu?
November 17, 2025, 21:50:37 »
Карма: +3228/-78
Quote from: solinus on November 17, 2025, 00:28:16
Utility menu
No, its not utility. I need some time to research for better solution
Suggestions
Player
Internet Radio
