Milkdrop for AIMP
Topic: Milkdrop for AIMP (Read 48399 times)
Milkdrop for AIMP
December 09, 2008, 15:19:50 »
GAGO61
Guest
hi friends..
i want to ask a question;
is there milkdrop plugin for aimp??
(milkdrop is a visual plugin for winamp)
Re: Milkdrop for AIMP
December 09, 2008, 15:33:13 »
anon
Guest
https://aimp.ru/forum/index.php?topic=5277.0
https://aimp.ru/forum/index.php?topic=5278.0
December 09, 2008, 15:45:18 »
GAGO61
Guest
thak u for help..
it is working
September 20, 2012, 19:12:15 »
xeo
Карма: +20/-0
Does anyone have milkdrop2 working in aimp3 ? Please answer.
September 20, 2012, 19:22:05 »
Карма: +1408/-191
https://aimp.ru/forum/index.php?topic=15616.0
September 20, 2012, 20:40:16 »
xeo
Карма: +20/-0
It doesn't talk about newest version of aimp and DL links are dead and it's in russian. For me it doesn't work. Maybe I do it wrong but I don't know russian.
Is it working for you?
September 20, 2012, 21:22:44 »
Карма: +1408/-191
profile:
or \AIMP3\Profile\
or \Documents And Settings\<UserName>\Application Data\AIMP3\
or \Users\<UserName>\AppData\Roaming\AIMP3\
September 21, 2012, 00:09:18 »
xeo
Карма: +20/-0
Hmm it works, thanks, but only with your Milkdrop 1.04b (vis_milk.dll). I used 3 different vis_milk2.dll Milkdrop 2 but I've got 3 different errors then.
Reply #8 on:
September 21, 2012, 00:36:53 »
Карма: +1408/-191
vis_milk2
change aimp_vis_winamp.ini from profile
Reply #9 on:
September 21, 2012, 01:51:05 »
xeo
Карма: +20/-0
Thanks, it's my first time mlkdrop2 actually works with aimp3. Do u have any newer version of vis_milk2.dll ? Your version is 2.0 and I think there is 2.25 already with winamp.
Reply #10 on:
September 21, 2012, 09:10:29 »
Карма: +1408/-191
New versions of milkdrop - need specific libraries
it does not work with AIMP
Reply #11 on:
September 21, 2012, 13:01:19 »
xeo
Карма: +20/-0
Yes, with that newest vis_milk2.dll from winamp I've got errors in aimp even if copying needed dlls.
Reply #12 on:
September 28, 2012, 03:17:49 »
OneMoar
Карма: +1/-0
here is milkdrop 2.00A for aimp its a bit buggy but it works ... most of the time
http://cl.ly/JlI9
what I need is someone to port THIS
http://www.un4seen.com/forum/?topic=8807.0
or make aimp able to load that plugin if you can get aimp to load that wrapper then you can get milkdrop 2.0e to work
Reply #13 on:
September 28, 2012, 14:26:05 »
xeo
Карма: +20/-0
It's 2.0D, not A, but I don't see any difference
Are there any? And do u know about any difference between 2.0D and 2.25?
Milkdrop for AIMP
