Android Auto, new problem with loading large folders
Topic: Android Auto, new problem with loading large folders (Read 176 times)
October 31, 2026, 01:41:07 »
Milkie
Hi,
I’ve been using AIMP on both Windows and Android/Android Auto (AA) for a while now and until recently everything has worked perfectly. Two days ago, a folder (holding about 1,200 songs) that was previously accessed without any issues at all could not be loaded via AA (same issue using wired or wireless).
That folder can still be loaded and accessed by PowerAmp via AA with no issues. That folder can also still be played on the car by AIMP,
IF
I start it on the phone and then start AA. It also still works without any issues on my phone if it’s not connected.
No updates were made to any phone apps nor to any wireless settings etc.
I’ve cleared the cache and data of both AIMP and AA and uninstalled/reinstalled AIMP with no luck.
Every single time I try to enter this folder on AA all I get is the loading/searching circle continuously going around on the screen. All other folders are still accessible and playable with AIMP.
I've double-checked and there are no battery or permissions restrictions set.
And help on sorting this greatly appreciated.
Thanks
AIMP 4.50
Android 15
Moto G54
Last Edit: October 31, 2026, 16:18:01 by Milkie
Re: Android Auto, new problem with loading large folders
October 31, 2026, 12:38:04 »
Карма: +3230/-79
What build of AIMP you exactly using?
October 31, 2026, 16:16:22 »
Milkie
Apologies, it's v4.31.1747
October 31, 2026, 23:03:33 »
Карма: +3230/-79
We have made no changes in 4.31 for Android Auto
