AIMP_RemovePlayed
Topic: AIMP_RemovePlayed (Read 895 times)
AIMP_RemovePlayed
September 25, 2026, 14:41:45 »
MHT
Remove Played
MHT
| 2026-10-14 | 229 KB |
App Version
: v5.40 or newer
Type
: Extensions
Target
: Windows 32-bit, Windows 64-bit
- Automatically removes played songs from the playlist
- Physical files on the disk are left untouched
- Starts working immediately after installation
- If the automatic deletion feature is not required, disable the plug-in.
When working with AIMP and large playlists, already played songs often accumulate in the playlist. This can make music management and radio program automation more difficult.
AIMP_RemovePlayed solves this problem by automatically removing a song from the current playlist after it has finished playing. Importantly, the plugin removes the entry only from the playlist without physically deleting the music file from the hard drive.
The plugin was developed with the idea of providing more convenient automation when using AIMP as a music or radio player. This allows already played songs to be removed from the list and makes subsequent program management easier.
AIMP_RemovePlayed can be useful both for home use and for building an automated radio system where the music playlist is continuously managed.
### Main Features
* Automatically removes played songs from the playlist.
* Physical files on the disk remain untouched.
* Suitable for large music playlists.
* Useful for automated radio playback.
* Works as an extension for AIMP.
The project was developed as a practical solution for users who want cleaner and more automated control over their AIMP playlists.
**AIMP_RemovePlayed – listen, remove from the playlist, and keep playing automatically.**
BG
При работа с AIMP и големи плейлисти често се натрупват вече изслушани песни. Това може да затрудни управлението на музиката и автоматизирането на радио програмата.
AIMP_RemovePlayed решава този проблем чрез автоматично премахване на песента от текущия плейлист след нейното възпроизвеждане. Важно е, че плъгинът премахва записа само от плейлиста, без да изтрива физически музикалния файл от твърдия диск.
Плъгинът е разработен с идея за по-удобна автоматизация при използване на AIMP като музикален или радио плейър. Това позволява вече изсвирените песни да не остават в списъка и улеснява последващото управление на програмата.
AIMP_RemovePlayed може да бъде полезен както за домашна употреба, така и при изграждане на автоматизирана радио система, където музикалният плейлист се управлява непрекъснато.
Основни функции
Автоматично премахване на изсвирени песни от плейлиста.
Физическите файлове на диска остават непокътнати.
Подходящ за големи музикални плейлисти.
Полезен при автоматизирано радио възпроизвеждане.
Работи като разширение към AIMP.
Проектът е разработен като практично решение за потребители, които искат по-чист и автоматизиран контрол върху своите AIMP плейлисти.
AIMP_RemovePlayed – слушай, премахвай от плейлиста и продължавай автоматично.
Contact:
https://mht.hopto.org
https://mht.hopto.org/MHTRadio/
Last Edit: October 14, 2026, 08:19:02 by Artem
Re: AIMP_RemovePlayed
October 09, 2026, 08:36:59 »
Карма: +3229/-78
32-bit version has wrong export function: _AIMPPluginGetHeader@4 (must be AIMPPluginGetHeader)
Strange behavior:
Plugin removes the track even if I skip it (track was played just few seconds).
I think this may raise questions among users.
About AIMP_CURRENT_TRACK.txt:
It’s not a very good idea to store it in the plugin folder; it’s better to store this file in the application profile folder. In older versions of the player, plugins are located in a write‑protected folder; moreover, some of our users work in a corporate environment and don’t have the ability to change the folder permissions. Starting with AIMP6, all custom plugins are placed in the profile folder, where write permissions are available.
Last Edit: October 14, 2026, 08:20:38 by Artem
October 11, 2026, 23:13:08 »
MHT
BG
Плъгинът е разработен за онлайн радио с цел да предотвратява повторното пускане на вече изслушани парчета. Файлът, който се записва, служи за съхраняване на информация за имената на текущите песни, така че радиото да може да я използва.
Ако плъгинът няма права за запис в съответната папка, това не е проблем — просто няма да създаде файла. Ако има необходимите права, файлът ще бъде записан нормално.
Плъгинът е създаден да работи в режим на случайно възпроизвеждане (Random/Shuffle), като позволява слушането на големи плейлисти без човешка намеса. Затова е реализирано автоматично премахване на вече възпроизведените песни от плейлиста, дори когато преминавате към следващата песен чрез Skip.
Това все пак е първата версия на плъгина. Ако има интерес, той може да бъде доразвит с необходимите функции и подобрения, така че да бъде по-удобен за всички, които желаят да го използват.
The plugin was developed for online radio stations to prevent tracks from being played repeatedly. The file it creates is intended to store information about the names of the current tracks, allowing the radio station to retrieve and use that information.
If the plugin does not have write permissions for the specified folder, this is not a problem — it simply will not create the file. If the necessary permissions are available, the file will be written normally.
The plugin is designed to operate in Random/Shuffle mode, allowing large playlists to be played without human intervention. For this reason, it automatically removes tracks that have already been played from the playlist, even if you skip them manually.
However, this is still the first version of the plugin. If there is sufficient interest, it can be further developed with the necessary features and improvements to make it more convenient for everyone who wants to use it.
Плагин разработан для интернет-радиостанций с целью предотвращения повторного воспроизведения уже прослушанных треков. Создаваемый им файл предназначен для хранения информации о названиях текущих композиций, чтобы радиостанция могла получать и использовать эти данные.
Если у плагина нет прав на запись в указанную папку, это не проблема — он просто не сможет создать файл. Если необходимые права есть, файл будет записан в обычном режиме.
Плагин предназначен для работы в режиме случайного воспроизведения (Random/Shuffle), позволяя проигрывать большие плейлисты без вмешательства человека. Поэтому он автоматически удаляет уже воспроизведённые треки из плейлиста, даже если вы вручную переключаете их с помощью функции Skip.
Тем не менее, это пока первая версия плагина. Если он вызовет интерес, его можно будет доработать, добавив необходимые функции и улучшения, чтобы сделать его более удобным для всех, кто захочет им пользоваться.
October 23, 2026, 03:39:03 »
Dypsis
Карма: +4/-0
Thanks.
I use single playlist mode, and I like the way it removes tracks even when I skip them. 👍
Other people may have different thoughts.
AIMP_RemovePlayed
