This behavior came with playing FLAC file. So i guess FLAC AUDIO Decoder MFT is a system decoder that relevant for this case.
What is your OS version (exact build number)?
the option should not affects to the result
Uh. for some reason AIMP destroying used device atMain 2026.09.22 16:56:58.296 D/ASO: WASAPI: Destroy Device - WASAPI Exclusive (Push): Speakers (Klipsch R-51PM)
I catch today after 48 min. the issue with WASAPI Exclusive (Event). It seems the time varies for some reason.
What were you doing at that moment?
Were you opening the program settings window?
