Suggestions
Audio 5.1 Channels
Topic: Audio 5.1 Channels (Read 459 times)
Audio 5.1 Channels
September 17, 2026, 19:41:54 »
Luckymehra990
Завсегдатай
Карма: +4/-2
Audiophile.
Hi devs do it supports multi channels in audio if it then how to enable it?
Surround Sound: Native down mixing and support for 5.1 & 7.1 multichannel audio, as my most files that i digitally purchased is 24Bit/48KHz - 6 Channels with 7.1 and 5.1 files.
And any chances to add show 5.1 channel counts in Audio details.
Thanks
Last Edit: September 17, 2026, 20:18:21 by Luckymehra990
Re: Audio 5.1 Channels
September 17, 2026, 22:39:35 »
Карма: +3227/-78
Does Android have native 5.1/7.1 channels support?
September 18, 2026, 05:40:50 »
Luckymehra990
Завсегдатай
Карма: +4/-2
Audiophile.
Not all androids but it can be simply implemented on the app which may be useful for Home System and speakers that supports it.
Many apps supports it properly
September 18, 2026, 07:42:58 »
Карма: +3227/-78
AIMP can play multichannel audio, but the app dowmix it to target number of channels
September 18, 2026, 09:34:04 »
Luckymehra990
Завсегдатай
Карма: +4/-2
Audiophile.
So any option to bypass it should be implemented in Nearby Future Updates?
Like this app i can play audio normally in my speakers and also via AIMP PC version too, same required on Android Variant too if possible
September 18, 2026, 10:31:42 »
Карма: +3227/-78
No, we have no plans to implement low level output bypassing Android OS .
September 18, 2026, 10:48:29 »
Luckymehra990
Завсегдатай
Карма: +4/-2
Audiophile.
Thanks for clarifying.
Suggestions
Audio 5.1 Channels
