What output settings you uses for the device?
try to increase device buffer
without any resampling by the audio engine
auto switch sample and bit rate: Is track 44kHz 16bit - device mode auto selected to 44kHz 16bit, If 48kHz 24bit - device mode auto selected to it, no resample needed no impact on audio source.
I mean: it would be top-super-mega to have good implemented WASAPI with (a little) user control GUI.
Allow buffer size change manually
Too small buffer size may lead to small sound gaps due playback.
In AIMP6, we've introduced option "allow device to choose preffered buffer size".
Firstly, this mode will only work for ASIO / WASAPI Exclusive, secondly, in this mode, the mix settings and gapless playback will not work at all.
