| AIMP for PC > Обработано / Processed |
| [-] [3083] [Linux] AIMP: The window has gaps in borders of screen |
| (1/5) > >> |
| shash:
I am on Garuda Hyprland Installed AIMP from your site all features work but the window never sticks to edges not on default and other skins also I have attached how the aimp window looks in full screen and non fulsceen modes My monitor resolution is 2560x1600 @ 1.59x in 16" I have tried with enabled and disabled states of - Snap windows to screen edges and other AIMP's windows - Allow per-pixel semi-transparency and gap still persisted on latest aimp have done system update and all packages are latest |
| Artem:
--- Quote from: shash on September 11, 2026, 22:26:59 ---Hyprland --- End quote --- Hyprland is not supported. It does not have required features |
| shash:
but i am using and everything is working perfectly fine only issue is it is not sticking to screen edge so i dont know what the issue is and why you are saying it does not have required features like i did not even have to do any changes all i did is install your package and it works out of the box on garuda hyprland |
| adem:
--- Quote from: Artem on September 12, 2026, 14:46:55 ---Hyprland is not supported. It does not have required features --- End quote --- I guess the only proper solution here is to address the issue in Hyprland. It would be nice if you could provide some extra info about the issue, so users could use it to report to the Hyprland devs. --- Похоже, что такой ответ не совсем понравился пользователю, и в принципе я его понимаю. Если это проблема Hyprland, то было бы здорово узнать о ней чуть больше, чтобы уже сами пользователи могли её перенаправить разработчикам. Так хотя бы есть шанс, что она будет поправлена, а не сгинет в пучине неизвестности. Да и это согласуется с духом Linux 8) |
| Алексей Долматов:
Я думаю, что вы неправильно поняли ответ разработчика. Я понимаю так, как написано. ОС не является поддерживаемой, т.е. не выполняется "отладка" (программирование, устранение ошибок плеера) под этот дистрибутив. Только, если баги косвенно могут быть исправлены из-за повторяемости в поддерживаемых ОС. Поддержка самой плеера в определённой ОС не предусмотрена, т.к. есть необходимость использовать какие-то функции, которых нет в этой ОС. Это не значит, что в самой ОС есть проблема. Это как с Windows XP. Формально, плеер может работать в этой ОС. Со стороны разработчика плеера это не целевая ОС продукта (плеера), поэтому сопровождение поддержки плеера в этой ОС не производится. Это не проблема ОС, просто в ней нет нужных функций. |
| Navigation |
| Message Index |
| Next page |
