AIMP is unable to play this radio stream
Topic: AIMP is unable to play this radio stream (Read 591 times)
October 07, 2026, 01:44:32 »
TheRedWaxPolice
Hi, first of all, love the android app, it's the best of the best...
The issue is the following, AIMP is unable to play this type of radio stream urls:
https://stream.nightride.fm/hls/nightride/aac_lofi.m3u8
This stream url works fine in other players like Foobar2000 etc.
I hope it can be solved...
Thanks...
Re: AIMP is unable to play this radio stream
October 08, 2026, 09:26:50 »
Карма: +3233/-82
That stream contains fragmented MP4 rather than plain AAC/ADTS, ie. each segment is a short MP4 file. Unfortunately, built-in decoders doesn't currently supports it. AIMP can play this stream using system codecs (in PC), but my Android device has no system coded that supports the stream.
