That's great. I will look out for it.I updated the app before making my post and saw that you had introduced a new feature that highlights the currently playing track. That's very helpful to me. Some of the podcasts I listen to are not numbered and I can lose track of where I am. I used to look at the playlength to work out which was which. Boss stuff!
I tried the new update. It partially worked and partially did not. The text is now displayed as English/Latin characters and I can read it. But, the formatting instructions are displayed in the text and not followed, instead of not being displayed by the text and used as instructions as to how to display the text. That may not be the clearest explanation, so the image below should make clear what I mean.
Also, can I make a suggestion for a new feature? I have begun using wireless headphones. What often happens when fiddling about with the controls, is that I accidently skip to a new track and lose my place in the podcast I was listening to. I then have to skip back and try to work out where I was. A first world problem, but a bit of a pfafff. Would you be able to include a feature that automatically bookmarks the position of the track you were listening to, (if that track is longer than say five minutes), every time you skip forward to a new track? That way instead of needing to manually find my postion in the previous track, (a big annoyance when the podcast is three hours long), I could just use the automatically created bookmark. This could be an option that people can turn on or turn off as they need.
