I didn't expect you to even bother replying, never mind creating a custom build!
Unfortunately, however, build 3070 doesn't seem to support the /DEBUG switch
rather the volume is set to zero, which isn't the same thing
Now could I also suggest adding a /PLAYLIST switch...?The playlist window is typically much bigger than the player window and so takes up a lot more space on the desktop.I think that being able to show or hide it for particular instances of the app with a "/PLAYLIST 1" and a "/PLAYLIST 0" switch would be an incredibly useful feature...🙏
