Equalizer behavior under AIMP 4.30
Topic: Equalizer behavior under AIMP 4.30 (Read 1244 times)
May 15, 2026, 21:15:58 »
Rfx9123
Завсегдатай
Since AIMP 4.30
Equalizer: each output device now has each own custom preset
How can I check or change the assignment? My DAP allows me to plug in wired headphones, switch the same output to SPDIF to connect it to a stereo system, or use Bluetooth for speaker output. But even with the new version of AIMP, I still have to manually switch between my own equalizer presets, just like before.
Device: iBasso DX160, Android 8.1
Re: Equalizer behavior under AIMP 4.30
May 15, 2026, 21:19:03 »
Карма: +3220/-78
1) Ensure that "Auto" is switched on
2) Select the preset after device connection. App will bind the preset to that device
May 16, 2026, 11:02:00 »
Rfx9123
Завсегдатай
Thanks for the quick reply. I wasn't aware that the "Auto" function triggered this behavior. I always thought it created an equalizer setting based on the music itself and hadn't activated it.
May 16, 2026, 14:41:05 »
Rfx9123
Завсегдатай
Sorry, but it's not working as expected. The "Auto" function seems to choose the equalizer setting based on the music track's tag, because after changing the output type, the setting is defaulted to "Rock". I'll leave "Auto" disabled for now.
