AIMP for Linux - make an option for minimum width of a playlist tab
Topic: AIMP for Linux - make an option for minimum width of a playlist tab (Read 913 times)
April 03, 2026, 13:23:20 »
rado84
Карма: +3/-4
Bulgarian
The title is self-explanatory. Make an option with a text field where we can enter minimum width (in pixels) for a playlist tab. I for one use only one tab at any time, so I have enough space to expand the width as musch as I want. Why? Because I have playlists with similar names and I wanna see exactly which playlist is currently running.
OR
If that's too hard to do, simply make the edge of the playlist tab expandable by dragging it with the mouse which size then will be written somewhere in the player's config files.
Last Edit: April 03, 2026, 15:21:36 by Artem
Re: AIMP for Linux - make an option for minimum width of a playlist tab
April 03, 2026, 13:24:35 »
Карма: +3216/-78
Its defined by a skin and cannot be controlled by user.
April 03, 2026, 13:28:43 »
Карма: +3216/-78
What skin you uses? What minimal width value you suggests to set?
April 03, 2026, 14:20:06 »
rado84
Карма: +3/-4
Bulgarian
That's too bad, then. I use a modified version of the Big Bento I made myself many years ago. I'd suggest minimum width of 250 pixels but if it's controlled by the skin, then can you give me a link to the skin editing tools? I used to have them but when I moved to Linux, I deleted them bc I didn't think I'd them anymore.
April 03, 2026, 15:21:19 »
Карма: +3216/-78
I am not sure that the Big Bento skin sources are published. You can find all required tools in our web-site.
April 03, 2026, 15:22:57 »
Choveka
Карма: +45/-8
Здравей. Скинредакторът се намира
тук
. Обаче за да редактираш скин за РС, ти трябва проекта на скина (с раширение .asc6proj ; .asc5proj ; .asc4proj ; .asc3proj или .asc2) Ако го нямаш проекта, няма как да редактиращ скина.
За Андроид е по-лесно. Всеки един обикновен скин може да бъде отворен в Скинредактора и да се редактира както ти душа сака
