2026/6/14 Local Lyrics Desktop Display Plugin
Pages:
All
Topic: 2026/6/14 Local Lyrics Desktop Display Plugin (Read 2455 times)
Re: 2026/5/22 Local Lyrics Desktop Display Plugin
Reply #15 on:
June 02, 2026, 22:39:59 »
rew
Карма: +1/-0
Вот никогда не сомневался АИМП лучший. В третий раз удволетворяет мои потребности. Спасибище. все как надо - исчерпывающе. Маленький ньюанс - при нажатии плей третье окно открывается еще внизу, маленькое...Как его выключить?
Reply #16 on:
June 02, 2026, 23:22:24 »
Карма: +3204/-77
I was preparing the plugin for publishing in our catalog and I've found few small issues:
1) Please check your content of your windows, it seems you've uses few controls with same name ("rowPanel" and "spacer"). Each control must be unnamed or has unique name (per window).
2) AIMP reports about leak in IAIMPUIForm, it seems you've forget to call Release() method of the base interface (IUnknown) after destroying the Form.
Pages:
All
