I was preparing the plugin for publishing in our catalog and I've found few small issues:1) Please check your content of your windows, it seems you've uses few controls with same name ("rowPanel" and "spacer"). Each control must be unnamed or has unique name (per window).2) AIMP reports about leak in IAIMPUIForm, it seems you've forget to call Release() method of the base interface (IUnknown) after destroying the Form.
Can Enhanced LRC be added as well? For now it displays them like this (attatchemnt)Example of:[00:17.21]Just <00:17.59>when <00:17.83>I <00:18.06>thought <00:18.86>I <00:19.11>got <00:19.71>him <00:19.95>to <00:20.21>fall <00:21.00>in <00:21.28>love <00:21.88>with <00:22.15>Tennessee[00:25.66]I <00:25.86>shoulda <00:26.33>known <00:26.84>better <00:27.75>than <00:28.53>to <00:28.79>take <00:29.26>him <00:29.78>back <00:30.36>to <00:30.64>Abilene[00:34.27]I <00:34.43>put <00:34.65>him <00:35.25>right <00:35.80>back <00:36.27>into <00:37.09>her <00:37.39>arms[00:38.63]I <00:38.81>wasn't <00:39.30>a <00:39.52>match <00:40.50>for <00:40.74>that <00:41.02>kinda <00:41.49>spark[00:42.35]
Your plugin is great! Many years ago I used MiniLyrics, which unfortunately is no longer maintained, and there’s only one feature I really miss from it.MiniLyrics could display several lines at once (I believe I used to set it to 2 or 3) and scroll them vertically as the song progressed. For me, this was much easier for singing because I could see the upcoming lines well in advance, and they always moved vertically in the same direction.With the current two-line mode, I can see the next line in advance, but there’s a problem: it's difficult to judge when exactly the next line will start.With a single-line display, the problem is even bigger: the next line simply isn't visible early enough.What I would really like is an option to display, for example, 3–5 lines at once and scroll them vertically. The current line could stay highlighted in a fixed position, with the upcoming lines always visible below it and moving up as the song progresses and with already implemented karaoke style Enhanced LRC.This would also make it much easier to anticipate when the next line starts, especially after a longer instrumental break or a pause in the vocals.That would make the plugin pretty much perfect for my use case.
