SAF unavailable on device?
Topic: SAF unavailable on device? (Read 2306 times)
March 27, 2026, 11:58:31 »
Eltorito
Hi, I can't delete mp3s when clicking on the bin icon.
Error as follows:
"The App has no write permissions to the Folder, to grant the permissions, please select in the next dialog the Folder and tap on the 'Select' button.
CANCEL / OK"
When I click OK, instead of taking me anywhere it displays the error message:
"Seems SAF is unavailable on your device"
AIMP version: v4.25.1673 (07.03.2026)
arm64-v8a, api29
System:
ATO S8 Series
Android 10
Thank you.
Re: SAF unavailable on device?
March 27, 2026, 13:18:32 »
Карма: +3222/-78
For these cases, we publishing no-saf version of app on our web-site.
March 27, 2026, 13:41:15 »
Eltorito
Thank you for your prompt reply.
I did use a link I found in a previous thread (
https://www.aimp.ru/?do=download.file&id=20
) but it didn't correct the issue.
I checked the page and couldn't identify the no-saf, could you send me an updated link? Thank you
March 27, 2026, 14:10:31 »
Карма: +3222/-78
Quote from: Eltorito on March 27, 2026, 11:58:31
Android 10
Oh, no-saf version is suitable for Android 11 or newer. Android 10 has no API that can be used instead of SAF. So, on Android 10 only SAF can provide full file access permissions.
