folders from USB to library
Topic: folders from USB to library (Read 89 times)
February 13, 2026, 15:06:03 »
pangio
Hi
You have probably answered my question somewhere in the forum, but it takes me too long to find the topics, so I'm starting them again.
I use AIMP to listen to music on my car android stero from USB drive mostly. I have all the files in subfolders (albums).
When I first pluged the USB, browsing through folders on AIMP it looked ok, it found all the subfolders and played all the files.
Once I deleted a couple of subfolders and added some new ones on my computer, AIMP didn't see them even after rescanning. The deleted ones dissapeared, but the new ones weren't there. I had to manually add them to library, so they would appear in usb folder.
Also in the "add to library" tab there were still the deleted folders (of course when I tried adding them, it said that they were unavailable).
Is it possible to make this automatically? I would like to access all the folders on USB drive without searching for them and adding them to library one by one.
Also I would like to know if it is possible to make AIMP play one folder after another- when the last song in folder 1 finishes, the first song in folder 2 automatically starts etc.
I'm used to older car stereos that play all the folders one after another. When I add some and delete some, it normally plays the added ones and there is no trace of the deleted ones.
I hope you understand everything and I'm looking forward to your answer.
Re: folders from USB to library
February 13, 2026, 15:36:58 »
Карма: +3183/-76
Quote from: pangio on February 13, 2026, 15:06:03
Select root folder to index.
