DennoN
[?] [3036] [Linux Mint] Can't load skin
Topic: [?] [3036] [Linux Mint] Can't load skin (Read 368 times)
February 05, 2026, 01:36:42 »
Zari
After the latest update on Linux Mint i receive the next error
https://i.imgur.com/8cOza0n.png
I am pressing exit from taskbar (the little green icon) and it closes now.
When i reopen AIMP it starts at default and works like this even with "Music Library" closed
https://i.imgur.com/Bc61Ne6.png
If i try to modify the skin and reopen AIMP in this sort of manner
https://i.imgur.com/UP1DcBB.png
i am receiving the same error
then everything starts over.
Basically AIMP can be utilize only in this way
https://i.imgur.com/bJKxqBb.png
no customization...
Sorry i provided some files on some previous error but Mint sent me there and i do not know how to reach again those directories. For more information help is appreciated to troubleshoot this error.
Last Edit: February 08, 2026, 14:33:05 by Zari
Re: [3035][Linux Mint] Can't load skin
February 05, 2026, 06:51:50 »
adem
Карма: +3/-0
QA-спец, Win10, Manjaro KDE, Android 15
1. Please, provide an archive with
~/.config/AIMP/
directory (you can attach it to the forum message if it is less than 4 MB)
2. Also try to start AIMP from console and see any Errors/Warnings during your activity. Or you can just attach console output here.
3. Try to rename
~/.config/AIMP
directory to reset the setting and to see if it fixes your issue.
Re: [?] [3035] [Linux Mint] Can't load skin
February 08, 2026, 11:13:29 »
Zari
Sorry for the super late reply.
~/.config/AIMP/ does not exist.
https://imgur.com/Apu7yX6
I attached a .txt file with the AIMP started from console.
Last Edit: February 08, 2026, 11:38:03 by Zari
Re: [?] [3036] [Linux Mint] Can't load skin
February 09, 2026, 22:39:46 »
Zari
Ok i found what @adem said with ~/.config/AIMP/
I could only access them while clicking Preferance and at the bottom "Profile Folder"
I had to remove the file "AlbumArts.Cache.db" because is too large and it sits around 11MB.
I provided the the folder in the archive attached.
February 10, 2026, 09:41:33 »
Карма: +3183/-76
Please, try on build 3037
February 11, 2026, 03:07:57 »
Zari
Same thing happens
https://i.imgur.com/u12ceo4.png
I attacked a .txt file from console.
February 11, 2026, 03:41:44 »
Zari
Having the player in the working state
and not with modified windows like this
now music stops.
Maybe is worth another topic.
While music just stops and not even another song can be played console tends to roll this things.
"Main 2026.02.11 02:14:14.569 D/MPRIS: Get: org.mpris.MediaPlayer2.Player.Position
Main 2026.02.11 02:14:25.569 D/MPRIS: Get: org.mpris.MediaPlayer2.Player.Position
Main 2026.02.11 02:14:36.569 D/MPRIS: Get: org.mpris.MediaPlayer2.Player.Position
Main 2026.02.11 02:14:47.569 D/MPRIS: Get: org.mpris.MediaPlayer2.Player.Position"
At those positions, somewhere, musics stops and the player can't start any song anymore.
I Highlighted area is where i opened "Preferences"
https://i.imgur.com/Zoxz3Sv.png
I attached a console "copy paste" to all the longs when music just stops and it continue to roll this message "Main 2026.02.11 02:14:36.569 D/MPRIS: Get: org.mpris.MediaPlayer2.Player.Position"
Also as it can be seen songs are on another partition and the partition is not NTFS
https://i.imgur.com/MvTbeTk.png
Partition name "9253d7fe-2aad-4abf-919d-01c6e71d1136" as in picture and console too.
Very Late Edit: According with this fixed bug
https://aimp.ru/forum/index.php?topic=77085.0
version 3038 looks like it does still "hangs".
To reproduce faster the "Can't load skin "": EDivByZero: Division by zero" the only thing i have to do is to move the "Playlist" to a "new window".
Last Edit: February 12, 2026, 17:18:38 by Zari
DennoN
