AIMP for Android v4.20
DennoN
[?] [3035] [Linux Mint] Can't load skin
Topic: [?] [3035] [Linux Mint] Can't load skin (Read 113 times)
Yesterday
at 01:36:42 »
Zari
After the latest update on Linux Mint i receive the next error
https://i.imgur.com/8cOza0n.png
I am pressing exit from taskbar (the little green icon) and it closes now.
When i reopen AIMP it starts at default and works like this even with "Music Library" closed
https://i.imgur.com/Bc61Ne6.png
If i try to modify the skin and reopen AIMP in this sort of manner
https://i.imgur.com/UP1DcBB.png
i am receiving the same error
then everything starts over.
Basically AIMP can be utilize only in this way
https://i.imgur.com/bJKxqBb.png
no customization...
Sorry i provided some files on some previous error but Mint sent me there and i do not know how to reach again those directories. For more information help is appreciated to troubleshoot this error.
Last Edit:
Yesterday
at 09:50:08 by Artem
Re: [3035][Linux Mint] Can't load skin
Yesterday
at 06:51:50 »
adem
Карма: +3/-0
QA-специалист
1. Please, provide an archive with
~/.config/AIMP/
directory (you can attach it to the forum message if it is less than 4 MB)
2. Also try to start AIMP from console and see any Errors/Warnings during your activity. Or you can just attach console output here.
3. Try to rename
~/.config/AIMP
directory to reset the setting and to see if it fixes your issue.
DennoN
