AIMP for Android v4.30
Disable resume playback
Topic: Disable resume playback (Read 2404 times)
January 10, 2026, 19:57:37 »
Ferscot
Previously, when tapping on a song to play it, I would get a message, basically asking if I would like to resume the file from the last position it was in the previous time I played it. I would always hit no or tap somewhere else on the screen to dismiss it.
Yesterday though, I decided to try and prevent it from popping up anymore, as I never intend to use that feature and always want my files to play from the start every time.
I selected No and hit the box to have the app remember my choice.
The next song I played though, on a different playlist, the message reappeared and I accidentally hit Yes along with having it remember my choice.
Now, every single song in every playlist is automatically starting from where it last was instead of the beginning, and the message doesn't even appear anymore so I can't seem to change it back. I've tried to use the settings menu but I can't find what's supposed to work for this issue.
I just want my files to Always play from the start every time they're selected. Can you please help me?
Last Edit: January 11, 2026, 17:12:26 by Soolo
Re: Disable resume playback
January 10, 2026, 21:56:51 »
Карма: +1402/-189
Prefrences - bookmarks - automatic
January 11, 2026, 02:36:39 »
Ferscot
This fixed it, thank you very much.
