Skin Editor, Skin Engine
get right data from providers
Pages:
All
Topic: get right data from providers (Read 13600 times)
Re: get right data from providers
Reply #15 on:
January 27, 2026, 13:52:57 »
Black_AVP_Bim
Тестер-Ветеран
Карма: +2086/-84
Я так и не понял, какая у вас задача и у меня нет возможности создавать проект на каждый ваш вопрос, тем более, что это элементарные вещи.
Посмотрите
тему
, в ней можно найти ответы на многие вопросы, а в этой
теме
есть конкретные примеры.
Reply #16 on:
January 27, 2026, 17:53:15 »
12costa
ok black_avp,
sorry for being too long.
now i have found half answers to my yesterday's question:
--to show a display that changes btw elapsed and remaining time it's better to use timedisplay element binded to prvplayerstate\trackposition (switching on click function is built already into the element)
---all metadata available for reading from prvplayingfile\fileinfo are listed under title formatting help in aimp option (sorry ...i know they are always the same but i can't know them by memory)
changing provider disable links to metadata via template property (and i oversaw this point... sorry)
Sorry to have bothered... I am trying to get where i would like... You know... "flawless skin or nothing"...
(just to update you (for fun) i am struggling now with resizing the skin with elements with negative margins... better to avoid those i guess... or perhaps ?!)
thank you for your support,
Filippo
Pages:
All
