AIMP Android: LRC Lyrics Not Showing During Playback
Topic: AIMP Android: LRC Lyrics Not Showing During Playback (Read 8082 times)
December 06, 2025, 09:06:16 »
kat
I’m using AIMP on Android and ran into an issue with LRC lyric syncing. Wondering if anyone here has seen this before or knows a fix.
Here’s what’s happening:
I’ve confirmed the MP3 and its matching LRC file are in the same folder with identical filenames.
AIMP can detect the LRC just fine and shows all the lyrics in the lyrics panel. (Screenshot ②)
The problem is: when the track plays, the lyrics don’t highlight or scroll in sync with the timing. In the playback screen, the lyrics don’t show up at all.(Screenshot ①)
So my question is: does the Android version of AIMP actually support scrolling, time-synced LRC lyrics?
If it does, I’m guessing I’m missing some setting. Any pointers would be appreciated! 🙏
Re: AIMP Android: LRC Lyrics Not Showing During Playback
December 06, 2025, 10:11:36 »
Карма: +3224/-78
Can you share the lyrics file that doesn't work?
December 06, 2025, 10:59:51 »
kat
Thanks a ton for being so helpful. I uploaded the mp3 and lrc files together to a temporary drive/link, so you can just click and grab them. Appreciate your effort!
https://we.tl/t-MWOw2P9tjU
December 06, 2025, 14:03:23 »
Карма: +1406/-191
Закинул файл на ftp
December 06, 2025, 18:16:54 »
kat
Quote from: Soolo on December 06, 2025, 14:03:23
Закинул файл на ftp
Так как мой файл превышал лимит загрузки в 4000 КБ, я залил lrc-файл отдельно.
December 09, 2025, 10:10:02 »
Карма: +3224/-78
What app version you using? I've tried to reproduce an issue on latest v4.25.1664 but failed, lyrics displays and highlights correctly:
