[x] [3016] prevents from system shutdown
Topic: [x] [3016] prevents from system shutdown (Read 1945 times)
November 02, 2025, 11:49:05 »
maciejak
Карма: +10/-0
Lastest Aimp 5.40 via ASIO => Rocks !!!
Hello
I have problem with Aimp 6 when i want automatic shutdown system windows 11. Aimp cause need confirm to finish shutdown system.
How can I disable this ability Aimp 6 ? For me is problem.
I need using automatic shutdown system because i can't every time make this manual, for example: i listen music in the night and go to sleep then i set automatic shutdown.
Please help
Last Edit: November 03, 2025, 14:04:12 by Artem
Re: Question about Aimp 6 priority in shutdown system
November 02, 2025, 13:01:53 »
Карма: +1408/-191
Show screenshot
November 02, 2025, 13:13:20 »
maciejak
Карма: +10/-0
I can't make screenshoot because for example press power button on case then screenshooting ddon't work.
I can say only what i see:
- screen with shutdowning system
- is question " Do You want save your work in Aimp ??
a) end and shutdown system or cancel
i have win11 pro 25H2
November 02, 2025, 15:42:04 »
Карма: +3230/-79
Quote from: maciejak on November 02, 2025, 13:13:20
AIMP doesn't show any confirmations by itself. Can you record a small video on a smartphone?
November 02, 2025, 16:15:20 »
maciejak
Карма: +10/-0
Ok, not now, for 4 hour.
November 02, 2025, 17:48:01 »
Карма: +477/-74
By default, the system should automatically shut down even if an application is pending. Check if you've installed any plugins that might affect system functionality, display errors, or prompts (dialog boxes). Check if the system is configured to shut down after a few seconds of waiting for programs to exit. This requires fine-tuning the system (registry), so read the instructions carefully. You may have disrupted system shutdown by using tweaks (programs, reg files, etc.).
The more information you provide about what you did with the player and system settings, the better the chances of determining whether the problem is on the player side or on the computer side.
November 02, 2025, 19:22:44 »
maciejak
Карма: +10/-0
I last time install aimp again and put folder settings from old installation. I install plugin dts, monkeymote and nextgroup.
I attachment video from like looking shutdown system.
Re: [3016] prevents from system shutdown
November 03, 2025, 14:04:08 »
Карма: +3230/-79
Thanks, I've reproduced and fixed the issue
