In the playlist the new cue causes the track within that new cue to get the name of the next track. And some tracks or the next one or the edited track is messed up after the edited track in the playlist or not playable or so. And when I copy the playlist entry to an old playlist of the same album, the error is copied as well.
Saving as plain text removes the original cue? Could Aimp automatically make a copy before overwriting / removing the original cue?
When one clicks the numbering option, could the original numbers of the original track be kept somehow? And not be changed when new chapters are added? So the chapters would get and a., b. or such? Or an additional numbering?
Could one just load a single track in the Chapter's Editor (instead of the entire album) when there are one big flac file (no single tracks) and a cue sheet?
In the playlist the new cue causes the track within that new cue to get the name of the next track. And some tracks or the next one or the edited track is messed up after the edited track in the playlist or not playable or so. And when I copy the playlist entry to an old playlist of the same album, the error is copied as well.Share the track, please.
Ah, sorry, forgot to mention, it happens to every single big flac / ape file containing all the tracks with a cue. The cue file always somehow gets messed up and / or the playlist (after dragging the cue over one and / or dragging an edited track from one to another playlist).
When I now drag the cue to a playlist and drag the edited track, respectivel the new chapter to another playlist it does not work properly. And the name of the new chapter has the name of the following track in the playlist.
to the playlist containing the (unedited 12) tracks of the album?
the other old playlist with the tracks not being edited in the Chapter's Editor will be changed / adapted to the new cue when the not edited track in the old playlist is played?
