[+] [2689] Discogs login issue
Topic: [+] [2689] Discogs login issue (Read 3606 times)
August 13, 2025, 18:31:18 »
jrnew01
I have been using this application for a long time without any problems, but in the latest update, it asks me to log back into Discogs to search for tags online, but I get an error when I try to do so: “system error. code: 10048.” Can you help me resolve this? Thank you!
Last Edit: August 14, 2025, 08:39:37 by Artem
Re: Discogs login issue
August 14, 2025, 08:39:27 »
Карма: +3220/-78
It seems that player failed to bind localhost:8090 address that uses to listen the answer from the online services.
Ensure that 8090 port is not blocked on your antivirus/firewall and not used by another app:
run following command in Windows Power Shell / Console (run it as administrator)
Code:
[Select]
netstat -abn | findstr "8090"
Re: [+] [2689] Discogs login issue
August 14, 2025, 10:51:23 »
jrnew01
C:\Windows\System32>netstat -abn | findstr "8090" TCP
TCP 0.0.0.0:8090 0.0.0.0:0 LISTENING
August 14, 2025, 11:14:58 »
Карма: +3220/-78
So, it does not display what app is bind this port?
August 14, 2025, 11:42:55 »
jrnew01
I was using Firefox, now I tried with Edge, but the error continues, although now other things appear with the command you gave me
October 11, 2025, 17:27:12 »
jrnew01
Finally I find the problem and kill the process
TCP 0.0.0.0:8090 0.0.0.0:0 LISTENING 3964
This is an third party app using the port "WsToastNotification.exe" wondershare
If somebody have the same issue in the future, maybe this post that can be help.
Thank you very much to everybody!
