Decoder
Topic: Decoder (Read 4416 times)
Decoder
June 01, 2025, 06:03:00 »
mdcowby
Ever since I installed the latest version I now get this Error Code: -1 (FFFFFFFF)
Message: Decoder was not found for this format. I get this now on a lot of music I have. Never did this before until I installed the new Version...what's the cause... Thanks
Last Edit: June 01, 2025, 11:06:52 by Soolo
Re: Decoder
June 01, 2025, 06:49:32 »
Карма: +477/-74
Check active and inactive plugins in the player settings. Check that the antivirus has not deleted some of the plugin files.
Be sure to specify the player version (with build) and the system version.
Re: Decoder
June 01, 2025, 08:44:11 »
mdcowby
Found the issue some how the files got corrupted when I transferred them the other day to my PC I grabbed the same song from a different backup and it worked fine. Thanks for you input. I must also say this player is great...
Decoder
