AIMP for Android v4.30
[?] [1565] Please support Shift-JIS in tag character code
Topic: [?] [1565] Please support Shift-JIS in tag character code (Read 10239 times)
April 27, 2025, 13:14:15 »
Tama
Карма: +2/-0
Hello,
I would like to support Shift-JIS in tag character encoding.
Some Japanese net radio and music file tags use Shift-JIS as the character code for tags.
Currently, AIMP does not support Shift-JIS, so Shift-JIS tags are displayed with garbled characters.
Since Shift-JIS is a common Japanese character code, we would like to support it.
Thank you in advance for your consideration.
Last Edit: August 12, 2025, 15:03:06 by Artem
Re: Please support Shift-JIS in tag character code
June 11, 2025, 19:12:20 »
Tama
Карма: +2/-0
Quote from: Artem on April 27, 2025, 19:48:24
Ok
Thank you very much!
I have confirmed that the update v4.15.1565 (09.06.2025) has resolved most of the garbled characters.
However, some characters are displayed as “�” and it seems that the original characters are not fully displayed.
I do not know the exact cause, but is it possible to correct the problem?
If it needs to be posted to Bugs as a defect, I will post it there again.
Here are some examples for your reference:
"だってアタシのヒーロー。" to "だってア�^シのヒ�[ロ�[。"
"君だけがヒーロー" to "君だけがヒ�[ロ�["
"ハッピーエンドプリンセス" to "ハッピ�[エンドプリンセス"
"複製サレタ街(Ver1.1a)" to "複製サレ�^街(Ver1.1a)"
"エルダの江戸講座" to "エル�_の�]戸講座"
"魔法のフラッシュ" to "魔�@のフラッシュ"
Examples of no problems:
覚醒ヒロイズム ~THE HERO WITHOUT A "NAME"~
メブキの日常
音色の彼方
