DennoN
Not play musics if i`m close and open again the app
Topic: Not play musics if i`m close and open again the app (Read 9534 times)
April 23, 2025, 17:30:03 »
Eliza91
Windows 10. Appear long time, need click in music again in folders and open again for play, if you leave app aimp the music stop next time open the app
Need close the app, go to folder musics and click for play again
If you click again for open, the music play again >>
Re: Not play musics if i`m close and open again the app
April 23, 2025, 19:23:42 »
Карма: +473/-73
April 24, 2025, 04:38:34 »
Eliza91
Quote from: Алексей Долматов on April 23, 2025, 19:23:42
this will not solve the bug "do nothing" option only will move the bug for not solve the problem.
April 24, 2025, 11:22:08 »
Карма: +473/-73
The screenshot does not show what needs to be selected, but where to see what is configured.
Previously I edited the message with the image incorrectly, so I lost the text.
Based on your description, the problem may be incorrectly identified. Please format the topic according to the section rules, attaching a link to a recording of a repeat of your problem, an additional screenshot or recording of checking the current player settings.
https://www.aimp.ru/forum/index.php?topic=5451.0
April 24, 2025, 13:53:29 »
Eliza91
Configuration is default, if you reset all configs, the problem continue, record screen will not necessary, the problem i talk is precise, since i talk this, not need record the screen, only close the app and open again, and the musics no have any sound, the music continue like equal MUTE sound, only play again if you click inside music in windows folder.
April 24, 2025, 14:03:31 »
Карма: +473/-73
Quote from: Eliza91 on April 24, 2025, 13:53:29
Do I understand correctly that the track progress (waveform) is filled and the playback time is running?
Then it looks like you have multiple copies of the player with different settings (output device or volume level).
Check the path to the application you are launching via the Windows Task Manager. Look carefully if the paths are similar (x86 and x64 program files, for example).
Also try to uninstall the program through the system settings panel (program list). If you can still open files or launch from a shortcut, then you definitely have two or more copies of the program.
April 24, 2025, 16:30:39 »
Карма: +3221/-78
As soon as it happened, refer to app settings \ playback and share screenshot of the settings page
May 22, 2025, 13:18:19 »
Eliza91
I found the problem: All these option inside not work, if exit aimp, and open again, never reproduce the sound again, need exit and open music by click again. Only work exlusive event and push, all other above normal not work.
All other options in end works, but have one problem if use another apps... look the issue... if work with event or push otpions not work other sounds like youtube or any other. stop all sounds.
Reply #8 on:
May 22, 2025, 13:27:50 »
Карма: +1406/-190
Reply #9 on:
May 22, 2025, 13:50:43 »
Eliza91
Quote from: Soolo on May 22, 2025, 13:27:50
You not see my comments above image! I already talk not work all sounds if this options is enabled, is not related this... is related other options not resume sounds!
Reply #10 on:
May 22, 2025, 13:54:35 »
Eliza91
Look, event or push sounds works, if exit aimp and open, the music works! but all other sounds stop, its ok... but other options not resume any sound and not possible use... need always click in windows music again for open... or sound will not work again, the bug appear in new versions, i simple use event sound because other options above, no one work if i close the aimp.
Reply #11 on:
May 22, 2025, 14:09:13 »
Eliza91
Reported video information: look until final! music will not play more with default configs, unistall and install again will not work, since i already speak, this problem occur in latest releases a time ago. look i close app and open again, not work!
https://www.youtube.com/watch?v=IgOYmez3lQQ
DennoN
