[?] [2673] Tray Icon Visibility
Topic: [?] [2673] Tray Icon Visibility (Read 4070 times)
April 21, 2025, 23:24:46 »
xTen
After updating to AIMP 5.40.2673, its tray icon is hidden after any Windows reboot/restart. And I have to unhide AIMP tray icon in tray (by drag and drop it next to the tray clock).
I use the AIMP portable version since 5 years ago and I had not such problem before (the OS is the same version as before, Win 11 24H2).
Last Edit: April 21, 2025, 23:48:30 by Artem
Re: Tray Icon
April 21, 2025, 23:48:15 »
Карма: +3227/-78
I failed to reproduce the issue on Windows 10. Tray Icon remembers it visibility between restarts
Re: [?] [2673] Tray Icon Visibility
April 22, 2025, 22:30:58 »
xTen
Yes. Exactly! AIMP is one of those special apps that in portable mode remembers its tray icon setting. The AIMP tray icon was good until the latest update. I remember it had this problem in two/three versions before the newest version, at the time I didn't report this, and the problem was solved by the next update. But in the latest update, the problem is back! It can't remember its tray icon setting after restart. As I said, I didn't install any OS updates, I didn't install any other software or apps, and I didn't change any settings in AIMP or OS. Odd, I am wondering why AIMP has to forget its tray setting.
April 23, 2025, 00:22:12 »
Карма: +3227/-78
But I don't changed tray icon code...
April 23, 2025, 23:17:19 »
xTen
Thanks 👍🏻...
Is there a way to trace the root of the problem? I'm not programmer/coder. Can I trace what causes the problem? I want to know it's a Windows/OS side or AIMP side fault.
