MS Surface RT
Topic: MS Surface RT (Read 2523 times)
MS Surface RT
April 10, 2025, 19:55:38 »
dgindlesperger
Does anyone know if the software will run on The Microsoft Surface RT OS? I want to use one as a music player/DAC, but needs to make sure that it works.
Re: MS Surface RT
April 10, 2025, 20:15:05 »
Карма: +474/-73
As you can see on the website, AIMP does not support ARM and ARM64, so you will have to look for another program.
Although you can read about plans for cross-platform support in the blog, you should not expect versions for older OS unless the developer has explicitly stated this in their plans for the future.
Re: MS Surface RT
April 10, 2025, 20:18:09 »
Карма: +474/-73
https://www.aimp.ru/forum/index.php?topic=59171
Here is a short answer as to why there was no version for this OS.
MS Surface RT
